How to use FRM files
 Product(s):ProSteel
 Version(s):CONNECT Edition
 Environment:N/A
 Area:Detail Style, 2D Drawing
 Subarea:N/A
Original AuthorSteffen Knoll, Bentley Product Advantage Group
What are FRM files used for and how to set them up properly?
Method
FRM files are part of the Detail Center Express solution.
There are currently three FRM files delivered with the installation. As the names indicate for different purposes.
It is recommended to copy one of the files ,so to use an own copy for adjustments.
The FRM files define:
- What tags in the used frame.dgn are filled with what information from the 3D model.
- They define the drawing file name and the drawing name based on chosen text and varibles.
- And they define list of used frame files and sizes as well as the use of containment list or part list.
All this will be shown in complete detail in following subpages.
Subpages:
