Applies To | |||
Product(s): | ProSteel 3D Professional | ||
Version(s): | 08.11.11.xx | ||
Environment: | N/A | ||
Area: | Part Databases | ||
Subarea: | |||
Original Author: | Johannes Michalowsky, Bentley Technical Support Group | ||
Lenght = nominal Length of the bbolt
Treatength = Length of the treat for future use
Article = Itemnumber
Head height =Height of Bolt head
Key width = Wrench width of the head
Gripmin = Minimal Grip length without washers and nuts (to calculate resulting Grip = Gripmin - Nut height - Washer height = minimum Grip length in tables) of the bolt
Gripmax = Maximum Grip length without washers and nuts (to calculate resulting Grip = Gripmax - Nut height - Washer height = maximum Grip length in tables) of the bolt
HoleDiam = recommended hole diameter
Boltweight = Bolt weight
Diameter double Diameter of the Bolt
Length double Length of the Bolt
TreatLength double Length of the Treat of the Bolt (for laster use)
HeadHight double Hight of the Head
Keywidth double Size of the Key of the Head
GripMin double Minimal GripLength possible for the Bolt
GripMax double Maximal GripLength possible for the Bolt
HoleDiam double Minimal HoleDiamter needed for this Bolt
Weight double Weight of this Bolt
Standard Char According to Standard i.e. DIN7990
CreatedBy Char Name of the Person created this record
CreatedAt Int Date of creation
EN-Norm Char According to EN-Norm
ISO_Norm Char According to ISO-Norm
Washers
FieldName Type Description
Article Char itemno of this Washer
HoleDiam double Minimal HoleDiamter needed for this Washer
Thick double Thickness of the Washer
InnerDiam double Inner Diameter of the Washer
OuterDiam double Outer Diameter of the Washer
Weight double Weight of the Washer
Standard Char According to what Standard i.e. DIN7990
Nuts and SafetyNuts
Article Char Itemno of this Nut
Height double Height of the Nut
Keywidth double Size of the Key of the Nut
HoleDiam double Minimal HoleDiamter needed for this Nut
Weight double Weight of the Nut
The GripLength range is used to calculate the appropriate bolt length needed.
