 Reference  |
 Summary Description  |
 Keywords  |
 394705  |
 System error creating a Design or Work Request when integrating with ProjectWise CONNECT Edition and using SQL Server in a 3 Tier configuration.  |
 ProjectWise Integration  |
 388922  |
 Unnecessary gaps appear in the Profile View caused by Scale Factor Y > 90.  |
 Network Profiles  |
 388139  |
 Need to change the cellname for ELECTRICSERVICEPOINT (DGN mode) from "electricservicepoint" to "electricservicepoint-3d".  |
 Configuration, Electric Workspace  |
 388102  |
 OpenUtilities Designer crash when closing the application.  |
 System  |
 386220  |
 The Dataloader and Model Administrator will only run on 32 bit Excel. 64 bit needs to be supported.  |
 Configuration, Excel  |
 383869  |
 The Pole feature should appear in the Electric Favorites menu.  |
 379206  |
 Profile scale factors for X,Y cause slight variances in the results.  |
 Network Profiles  |
 378342  |
 Profile Structure Width incorrect when X Scale Factor > 1.  |
 Network Profiles  |
 377605  |
 Profile with large scale factors using Reverse Option generates incorrect Profile  |
 Network Profiles  |
 376420  |
 Application is looking for usertool.dat and systemtools.dat file at invalid location on Windows 7.  |
 Installation  |
 376388  |
 Profile Reverse option generates incorrect profile.  |
 Network Profiles  |
 373327  |
 Network Analyzer – session stops working when Network Trace form is cancelled and then Place Bundle is canceled while using options for Conduit Network with Trace Results, Place In Results and Place Bundle.  |
 Network Trace, Layouts  |
 373324  |
 Network Analyzer – session stops working on switch to other DGN when in Trace Results form.  |
 Network Trace  |
 372877  |
 Refresh context not working for custom tools on right click menu.  |
 User Interface  |
 372876  |
 Memory leak in Feature Type view mode  |
 Design Assistant  |
 372875  |
 Performance problem in Feature Type view with large designs.  |
 Design Assistant  |
 371604  |
 Workflow Manager Report Manager fails to find the correct environment variable for reports.  |
 Reporting  |
 371540  |
 Workflow Manager about screen contains junk character and is missing a logo.  |
 Branding  |
 371535  |
 OpenUtilities Map Copyrights should be updated for 2016.  |
 Copyrights  |
 371534  |
 OpenUtilities PowerView Copyrights should be updated for 2016.  |
 Copyrights  |
 369940  |
 Gas Compute Leak Statistics does not recognizes valid leak features.  |
 Analysis Tools  |
 368856  |
 Dimension features changed to white, not visible using default preferences.  |
 Configuration, Symbology, Data Model  |
 368413  |
 Work Location annotation changed to white, not visible using default preferences  |
 367793  |
 Associate/Disassociate from Design list not using StateAvailableActions  |
 Workflow  |
 365909  |
 System error on drag and drop of gas point features with SQL Server  |
 Configuration  |
 365900  |
 Smart Move/Smart Modify - linear text is not move correctly  |
 Edit Tools  |
 365898  |
 Smart Move/Smart Modify - dialog failed to load when BUC contains a networktype not containing a network  |
 Edit Tools  |
 365244  |
 Switch cabinet connectivity is not set correctly.  |
 Configuration  |
 365234  |
 Switch Cabinet templates use old data model.  |
 Configuration  |
 362736  |
 Water Elevation tab in the editor appears blank.  |
 Feature Editor  |
 357639  |
 Gas Label attribute contains the "|alias|" specifier.  |
 Configuration  |
 353193  |
 Gas symbols placed at incorrect scale using Place at Distance  |
 Placement Tools  |
 351791  |
 Annotation Placement Issue after customization  |
 Placement Tools  |
 346999  |
 Peer Relation table columns are too short.  |
 Data Model  |
 346544  |
 Closing editor dialog causes subsequent placement operations to not restart.  |
 Placement Tools  |
 344362  |
 Shortcut bar context menu still reads "Hide BUD Bar"  |
 Branding  |
 343967  |
 Residual highlights occur after Disconnect Features command is aborted  |
 Edit Tools  |
 343252  |
 Erased Spatial Cached Instances invokes PreDeleteHook with an active feature placement  |
 API  |
 343248  |
 Query Spatial features invokes PreInsertHook with an active feature placement  |
 API  |
 341121  |
 Inconsistent and/or incomplete product names in Workflow Manager panels  |
 Branding  |
 329615  |
 Error "New transaction is not allowed because there are other threads running in the session" while CU list loads.  |
 User Interface  |
 323742  |
 Using a feature editor during a trace session can block the user's ability to select the From feature for a trace.  |
 Network Trace  |
 323358  |
 Workplace Today supervisor view not grouping users correctly.  |
 User Interface  |
 152491  |
 PowerView Help has incorrect path.  |
 Help  |
