Product(s): | promis.e V8i & promis.e 2007 | ||
Version(s): | v3.0 through 08.11.08.xx | ||
Environment: | N/A | ||
Area: | Platform Support | ||
Subarea: | N/A |
For software versions more recent than promis.e V8i SELECTseries 3 (08.11.08.xx), see the current article: [[3719|Compatibility Chart - promis.e]]
promis.e V8i is version 08.11.05.9x
promis.e V8i SELECTseries 1 (SS1) is version 08.11.07.82
promis.e V8i SELECTseries 2 (SS2) is version 08.11.07.150
promis.e V8i SELECTseries 3 (SS3) is version 08.11.08.14
Refresh release for promis.e V8i SELECTseries 3 is version 08.11.08.22
MicroStation/PowerDraft V8i is version 08.11.05.17
MicroStation V8i SS1 is version 08.11.07.171
MicroStation PowerDraft V8i SS1 is version 08.11.07.172
MicroStation/PowerDraft V8i SS2 is version 08.11.07.443
The "standalone" version of promis.e runs on MicroStation PowerDraft. PowerDraft is a separate download and installation.
Important Notes:
When there are both 32-bit and 64-bit versions of a particular AutoCAD version, the 32-bit version will not install on 64-bit operating systems, nor will the 64-bit version install on 32-bit operating systems. So if the operating system is 64-bit, be sure the version of promis.e to be installed is compatible with that version of 64-bit AutoCAD and the operating system.
For Oracle 11g with promis.e V8i SS2 and SS3, install the 11.1.0.7.0 Instant Client. Installing the Oracle Universal Installer ODAC1110720.zip is a convenient way to install this client and other the other requirements for Oracle with promis.e V8i SS3. Later releases of the Oracle 11g client such as 11.2.0.1.0 are not compatible with promis.e V8i SS2 or SS3. Install the 32-bit version of the client if using 32-bit promis.e even if the operating system is 64-bit (i.e. promis.e for PowerDraft). Install the 64-bit client if using 64-bit promis.e (i.e.promis.e for 64-bit AutoCAD).
[[6255|Project Database Version TN]]
Original Author: | Bentley Technical Support Group |
