Product(s): | Promis.e, Bentley Substation | ||
Version(s): | through 08.11.13.96 | ||
Environment: | N\A | ||
Area: | ProjectWise Integration | ||
Subarea: | N\A |
When trying to delete the project using ProjectWise Explorer:
Error Information
Last Error [ 58007 ]
Error deleting a folder.
Error deleting a folder. A folder has documents which can not be removed. Remove those documents first.
When trying to delete the ect.fid file using ProjectWise Explorer:
Document Delete Failed
Error -1 while deleting document "ect.fid".
Error message is:
Substation ProjectWise information.
Cannot remove the Electrical project configuration file.
While Electrical projects can be created using ProjectWise Explorer, they must be deleted using [[Project Manager]].
Open [[Project Manager]]
Find the project, right-click it and select Delete.
Original Author: | Matt_P |
Keywords: ProjectOptions.xml, desktop.ini
