Bentley OpenUtilities V8i (SELECTseries 4) 08.11.09.802 - Update 3 Resolved Issues List
ID |
Title |
683882 |
Linked attribute updates with multiple feature instances at one work location |
679460 |
Localized OpenUtilities PowerView Help menu does not work |
679456 |
Localized OpenUtilities PowerView does not include print prep |
679047 |
Performance issues streaming spatial data with relationships |
678470 |
Moved the Database folder from Installset to deployment |
669033 |
OpenUtilities Workflow Manager Splash screen obscures the latest CONNECT Center Login |
664650 |
Unable to edit the value of an Integer type Global Attribute in Job Default Assistant |
658720 |
Text global defaults show incorrectly in Design Assistant |
654180 |
Design validation status is not reset by changes to the design |
653645 |
Display Connection setting does not work on SQL Server |
653644 |
Performance impact of large landbase features in Design Assistant |
652055 |
Undo & Redo of Pole deletion in Design Assistant causes crash |
651518 |
Disassociate not available in Work Request view |
651514 |
Error when submitting multiple copies of a CU Assignment at a Work Location |
644898 |
Job Scheduler has an Unhandled exception and crash on selection of Help About |
639165 |
Inconsistent error on expand path in Design Assistant |
639149 |
System error "DELETE statement conflicted" occurs when deleting a span with an existing Points-Only Non-Split work location |
637294 |
Folder Custom Queries are limited to 1200 chars |
631486 |
Sporadic crash on Get Selection of Underground Secondary |
631483 |
Gas Casing not attaching to gas main |
624503 |
OpenUtilities Power View - Print Prep is not on the Utilities toolbar |
623737 |
OpenUtilities Powerview - two “Print” options under the “File” pull down menu |
619961 |
ctrl keys do not work in comments dialog |
615729 |
Design Assistant find in unit catalog highlights but does not select result |
615727 |
Design Assistant Find button is not the default button |
613617 |
Model Administrator macro is causing virus scan to report false positive |
591896 |
Renumber of Work Location with no annotation in the Bentley desktop GIS causes a crash |
591894 |
Job Scheduler service fails with max size password |
591891 |
Job Scheduler UI is not showing status correctly when it’s not running as a service |
567874 |
PrintPreparation is not working in OpenUtilities PowerView |
539831 |
Outage Planner tool can crash with small networks |
538454 |
Edit Feature and use of MS_GEOXFM_NO_DYNAMICSCOREDFEATURES=1 raises GetConnections failed error message |
538390 |
Model Administrator - AddSymbologyAdditions is not getting processed |
527294 |
Drag and drop of non-Proposed Install features causes an error |
527292 |
Copy paste of features between Work Locations is inconsistent |
495432 |
Ungraceful exit when trial license has expired |
444693 |
Leak analysis cross tab report has 'mile' in the label |
439919 |
Breaks per year per length calculation is wrong |
434860 |
Unable to access XfmStdUtilPlacement.XFMStdPlacementEventHandler in mvba |
434591 |
Plan Outage action (Create OutagePlan design fails) when only the Water Configuration is loaded |
434589 |
Corrected Water>Outage Plan Workflow |
433988 |
Exception can occur when editing referenced features outside the OpenUtilities data models |
388449 |
Smart Move and Smart Modify are not handling design comments |
365899 |
[Smart Move and Smart Modify are not handling multi-line text |
