Product(s): | ProStructures | ||
Version(s): | CONNECT Edition (10.XX.00.XX) | ||
Environment: | N/A | ||
Area: | Backstage | ||
Subarea: | N/A | ||
Original Author: | Vyanktesh Nama, Bentley Product Advantage Group |
In this wiki, we are going to learn how to identify the installed ProStructures CONNECT Edition version.
A] From the Backstage:
1. Launch ProStructures CONNECT Edition, go to Backstage File > Help and here click on About ProStructures CONNECT Edition.
2. Now, About ProStructures dialog box will open. Here we can find the complete version of ProStructures CONNECT Edition.
Note: To open above the same dialog, one can use the Key-in "dialog aboutustn"
B] From the Key-in dialog:
1. Open the Key-in dialog and type "ProStructure Show Version" then press Enter key.
In this way, we can identify the installed ProStructures CONNECT Edition version.
