| Product(s): | ProStructures CONNECT Edition | ||
| Version(s): | CONNECT Edition (10.01.00.23) | ||
| Area: | Configuration | ||
| Subarea: | Workspace / Workset | ||
| Original Author | Sandip Kar, Bentley product Advantage Group |
Workspaces are similar to Localization in previous versions of ProStructures.. In previous version it was known as localization which is converted into Workspace in CONNECT Edition
To know the active Workspace in which your current model is running, need to go backstage, File > Settings > Configuration and there need to go About Configuration.
