Error - Could not load Microsoft.ReportViewer.ProcessingObjectModel
 Product(s):Promis.e, Bentley Substation
 Version(s):08.11.11.18
 Environment:N/A
 Area:OS Support
 Subarea:N/A
Error or Warning Message
The following error message or similar appears when using PLC Generator and possibly other tools.
An error occurred during local report processing.
The definition of the report 'Main Report' is invalid.
An unexpected error occurred in Report Processing.
Could not load file or assembly 'Microsoft.ReportViewer.ProcessingObjectModel. Version=8.0.0.0, Culture=neutral. Public Token=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified.
Explanation
"Microsoft.ReportViewer.ProcessingObjectModel" is part of Microsoft Report Viewer, which may be corrupt or was never installed.  "Version=8.0.0.0" corresponds to Microsoft Report Viewer 2005 SP1.
How to Avoid
Download and install Microsoft Report Viewer 2005 SP1
http://www.microsoft.com/en-us/download/details.aspx?id=4016
If a different Version is specified in the error message, a different version of Microsoft Report Viewer may be required to be installed.
 Original Author:Matt_P
