| | Product(s): | Promis.e for AutoCAD | |
| | Version(s): | 08.11.05 - 08.11.11.85 | |
| | Environment: | N/A | |
| | Area: | Interoperability | |
| | Subarea: | N/A | |
Error or Warning Message
"The Ribbon does not have any tabs or panels currently loaded."
Steps To Resolve
- In Promis.e, type OPTIONS at the Command prompt. This will open the Options dialog.
- In Options, select the Files tab, expand Support File Search Paths, and note the path. It should be something like:
C:\Documents and Settings\(your login)\Application Data\Autodesk\AutoCAD 2009\R17.2\enu\Support
or
C:\Users\admin\AppData\Roaming\Autodesk\AutoCAD 2009\R17.2\enu\Support - Close the Promis.e application.
- Browse to the path noted using Windows Explorer.
- Copy the acad.CUI file or acad.CUIX file located in that folder to another folder as a backup.
- Start plain AutoCAD.
- Type OPTIONS at the command line.
- Select the Profiles tab, select the <> profile, and click Set Current. Delete the "promise" and "ECAD_CAD" profiles.
- Close the Options dialog.
- Type CUI at the command line. This will open the Customize User Interface dialog.
- In the upper left pane on the Customize tab, right-click on "ACAD" at the very top of the tree and select Reset ACAD.CUI. Click Yes at the prompt. Click OK to exit the Customize User Interface dialog.
- Start Promis.e.
P/S: 42491
