| Version(s): | 08.11.07.82 | ||
| Area: | Administration Features | ||
| Subarea: | Setup |
When the Finish button is clicked when creating a new Parts Database Path, the following error occurs:
Unhandled exception has occurred in a component in your
application...[DBNETLIB][ConnectionOpen (Connect()).]SQL Server does not exist or access denied.
Invalid connection string attribute.
************** Exception Text **************
System.Data.OleDb.OleDbException: [DBNETLIB][ConnectionOpen
at MDBProxy.ConnectionManager.NewConnection(String strConnection)
at MDBProxy.Proxy.NewConnection_String(String strConnection)
at ECT.ECAD.DAL.DBParts.GetColumns(String m_TableName, String connstr)
at ECT.ECAD.DAL.DBParts.CheckMapFields(String userpartdbconstr, String usertable, String defpartdbconstr, String deftable, DataTable MappingRelation)
at ECT.ECAD.UI.DAddPartDB.btnFinish_Click(Object sender, EventArgs e)...
This error results when trying to create a parts database path without a valid connection to a promis.e SQL project database. Establish a connection to a project database on the Project Database tab of the [[Setup]] dialog before attempting to create a parts database path. A valid project database connection is evidenced by receiving no error messages when clicking the Apply or OK buttons on the [[Setup]] dialog and by the ability to open and create projects and project pages.
[[Troubleshooting Project Database Connection Problems]]
| Original Author: | Matt_P |
P/S: 38641,500000065290
