Product(s): | Promis.e, Bentley Substation | ||
Version(s): | 08.11.13.57 - 08.11.13.140 | ||
Environment: | N\A | ||
Area: | Automation Features | ||
Subarea: | Project API Builder |
After specifying a .XLSX file on the [[Project API Builder]] dialog or in [[Project Manager]] > BOM Explorer > Import Spreadsheet Into BOM, an error message appears that includes the following text.
The 'Microsoft.ACE.OLEDB.12.0' provider is not registered on the local machine
In one case the error message was:
Information
Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
at System.Data.Common.UnsafeNativeMethods.lDBlnitializelnitialize.lnvoke(lntPtr pThis)
at System. Data.OleDb.DataSourceWrapper.lnitializeAndCreateSession(OleDbConnectionString constr. SessionWrapper sessionWrapper)
at System. Data.OleDb.OleDbConnectionlnternal..ctor(OleDbConnectionString constr. OleDbConnection connection) ...
In the case of a Windows 8.1 64-bit operating system with 64-bit Microsoft Office 365/2016 installed, the error message was resolved by installing the 2007 accessdatabaseengine.exe available here.
HOW TO: FIX ERROR - "the 'microsoft.ace.oledb.12.0' provider is not registered on the local machine"
Original Author: | Matt_P |
Keywords: OLEDB, TFS 78121
