ProjectWise dialog does not appear for attaching reference, opening file
Product(s):Bentley Substation, Promis.e
Version(s):through 08.11.13.140
Environment:N\A
Area:ProjectWise Integration
Subarea:N\A
Problem Description
When I try to attach a file as a reference, the standard file system explorer dialog opens instead of the Select CAD File dialog, so I cannot browse files stored in ProjectWise.
The problem may also occur with File > Open or other tools.
Steps to Resolve
Ensure the [[Install the ProjectWise custom module for ProjectWise Explorer|custom module for ProjectWise Explorer is installed]] and the [[Setup]] > ProjectWise dialog is configured properly.
If ProjectWise integration is installed and configured properly try the following.
Option 1
  1. Open [[Setup]] and select the ProjectWise tab.
  2. Clear the Enable ProjectWise integration check box, click OK.
  3. Close Bentley Substation/Promise.
  4. Open Bentley Substation/Promis.e.
  5. Open [[Setup]] and select the ProjectWise tab.
  6. Set the Enable ProjectWise integration check box, click OK.
Option 2
  1. Select Workspace > Configuration from the main pull down menus in Bentley Substation/Promis.e.
  2. Look for a PW_DISABLE_INTEGRATION variable. If it exists and is set to 1, that may be the problem. This would be coming from the pw.cfg file, found in a path like:
    C:\Program Files (x86)\Bentley\Substation V8i\Substation\config\appl\
    or
    C:\Program Files (x86)\Bentley\promise V8i\promise\config\appl
There is logic in the pw.cfg file that sets PW_DISABLE_INTEGRATION if it does not find what it likes. The following procedure resolved the problem for one user.
  1. Open pw.cfg in a text editor such as Notepad.
  2. Comment out the PW_DISABLE_INTEGRATION_FROM_DESKTOP=1 line by inserting a # at the beginning of the line if one is not present already:
    #PW_DISABLE_INTEGRATION_FROM_DESKTOP=1
  3. Restart Bentley Substation/Promis.e
 [[Install ProjectWise integration]]
 Original Author:Matt_P
