| Product(s): | Promis.e | ||
| Version(s): | through 08.11.13.96 | ||
| Area: | Migration | ||
| Subarea: | N\A |
After clicking OK on the New Page dialog, error message(s) are displayed:
Internal Error
API Error Message: Could not find file '....ANSI-IEEE_T.Dwg'
TargetSite: Void WinIOError(Int32, System.String)
DeclaringType: System.IO.__Error
Attributes: internal static
MemberType: Method
StackTrace: C:\ProgramData\Bentley\Promise V8i\Config\LastError.txt
Product Version: Promise V8i (SELECTseries 8)
DB Version: SQLServer 8.1.42
and no page is created, or
Error
An error occured when saving
Detail:Object reference not set to an instance of an object.
is displayed followed by:
Internal Error
UI Error Message: Object reference not set to an instance of an object.
TargetSite: ECT.ECAD.API.Page New(ECT.ECAD.API.PageSetting)
DeclaringType: ECT.ECAD.API.Pages
Attributes: public
MemberType: Method
and a page drawing may appear on the screen.
These error messages can occur after migrating from Promis.e for AutoCAD to Promis.e Standalone. The problem is that the ProjectOptions.xml file that the project(s) is based on still points to DWG files instead of DGN files as seed files for new pages.
Note: when Promis.e for AutoCAD projects are migrated to Promis.e Standalone V8i SELECTseries 6 and above, the seed file extensions in the Project.Options.xml file in the project will get converted to ".dgn". But there is no migration function for template ProjectOptions.xml files.
[[Moving From Promis.e for AutoCAD to Promis.e Standalone]]
[[Template Project Options]]
| Original Author: | Matt_P |
Keywords: occurred, TFS 6102
