| Product(s): | Promis.e | ||
| Version(s): | through 08.11.11.85 | ||
| Area: | Interoperability | ||
| Subarea: | N/A |
Title blocks or other objects on the project pages appear dim or dark, not as bright as other objects.
Locked layers in recent versions of AutoCAD appear darkened, and Promis.e title blocks are on locked layers. The dim appearance on screen does not affect plotting; the pages will print normally.
To adjust the darkness of locked layers, use the LAYLOCKFADECTL system variable.
| Original Author: | Matt_P |
Keywords: faint, light
P/S: 35986, 500000062731
