Product(s): | ProStructures & ProSteel |
Version(s): | CONNECT Edition (10.XX.00.XX) |
Environment: | N/A |
Area: | Steel Modelling |
Subarea: | Steel Connections |
Original Author: | Alistair Lobo, Bentley Product Advantage Group |
An end plate connection is placed rotated by 90 degrees, contrary to required. How can this connection then be turned ?
The connecting profile is a rectangular hollow section. This plays a role with connections and here the profile has been inserted rotated by 90 degrees.
Now, in the PS Properties, if the profile is again rotated using the -90 or +90 degree button, the connection also rotates.
In this manner, one can control the orientation of the connection by selecting the position / rotation of the connecting member.
