| Version(s): | through 10.01.00.23 | ||
| Area: | Administration Features | ||
| Subarea: | Setup |
The list of catalogs in Catalog Paths specifies which catalogs are available when creating or placing symbols, macros, title blocks, and device families. The order of the catalog paths in the list determines the order in which the catalogs are searched. The topmost catalog path will be the default catalog selected when saving items to a catalog.
In V8i, catalog paths are configured on the Setup dialog, affecting all projects.
In the CONNECT Edition, catalog paths are first configured for the WorkSpace, which can contain several projects. The WorkSpace catalog paths can be appended to, prepended, or ignored (overwritten) by project-specific catalog paths.
To view or modify the catalog paths for the WorkSpace:
To view or modify the catalog paths specific to the project:
Select [[Setup]] > Catalog Paths
[[Deployment Guide - Substation CONNECT Edition]]
[[Add Catalog Path]]
[[Create a new catalog]]
[[Rename a catalog]]
| Original Author: | Matt_P |
