Product(s): | ProStructures, ProSteel |
Version(s): | CONNECT Edition (10.XX.00.XX) |
Environment: | N/A |
Area: | Shapes/Objects |
Subarea: | N/A |
Original Author: | Alistair Lobo, Product Advantage Group |
Stiffeners can be created by a certain length. The position, top or bottom, is depending on the insertion point.
1) Apply the Stiffeners tool
2) Determine the position on insertion point of the Stiffener and apply the settings as in the below picture to configure the stiffeners by length
3) In this manner, stiffeners can be created with respect to length
