| Version(s): | through 10.01.00.23 | ||
| Area: | Administration Features | ||
| Subarea: | Setup |
How do I configure the software to use an existing catalog?
Users often need to configure the software to use a catalog created by someone else, such as a downloaded manufacturer catalog, their standard corporate catalog, or a catalog from a client or vendor. This article describes how to incorporate a catalog in the form of a folder, not a file with a .CTLG extension. For files with a .CTLG extension, see [[Import Catalog]].
Notes:
In V8i, catalog folders are often kept in the [[5367|promis-e Data folder]] or [[Substation Data folder]] but can be located elsewhere.
In CONNECT Edition, catalog folders are often kept in the WorkSpace folder. For example, an out of the box path would be
C:\ProgramData\Bentley\Bentley Substation CONNECT Edition\Configuration\WorkSpaces\Substation Example\Standards\Substation\Catalogs
It is possible to add more than one catalog to Catalog Paths.
A catalog path is also added to the configuration when a catalog is [[Import Catalog|imported]] and when a catalog is [[Create a new catalog|created]].
When there are duplicate symbol names in different catalogs, the symbol definition in the catalog that is highest in the Catalog Paths list will be used. Similarly for macros, families, and title blocks. Change catalog priority by moving it higher or lower in the Catalog Paths list using the up and down arrow buttons.
[[Create a new catalog]]
[[Import Catalog]]
[[3590|Adding Manufacturer Data To promis.e]]
| Original Author: | Matt_P |
