| Product(s): | ProSteel for AutoCAD | ||
| Area: | External Partlist | ||
| Subarea: | Partlist Creation | ||
This Wiki will guide you on how to create external Partlist or Bill Of Material for Single Parts , Groups, Assemblies etc. in ProSteel for AutoCAD.
Before creating partlist, positioning needs to be done for the required steel parts. For more information on how to position the steel parts, please follow the below wiki link.
WIKI: How to positioning steel elements automatically in ProSteel for AutoCAD?
Once you done with the positioning of the steel parts then please follow the below steps to create external partlist.
1. Go to ProSteel > Edit > Create Partlist Database.
OR
Type PS_PARTLIST in the command line and hit Enter to open Partlist Creation dialog.
2. In the Partlist Creation dialog, set all your required options.
3. For the next steps, please follow the below wiki link of ProSteel CONNECT Edition.
WIKI: How to create ProSteel Partlist?
In this way, you can create external partlist in ProSteel for AutoCAD.
