| Product(s): | ProSteel for AutoCAD | ||
| Area: | External Partlist | ||
| Subarea: | ProStructures Partlist | ||
This Wiki will guide you where one can customize the List (*.lst) file to print required partlist in ProSteel for AutoCAD.
To customize the List (*.lst) file, one needs to open/load the partlist database file in the ProStructures Partlist dialog. For more information on how to open or load the partlist database, please follow the below wiki link.
WIKI: How to load existing partlist database in ProSteel for AutoCAD to print partlist?
Once you load the partlist database file in the ProStructures Partlist dialog then please follow the below steps to customize the list file.
1. In the ProStructures Partlist dialog, go to Settings > Edit Partlist Definition.
2. Now, select your required LST file and click on the Open button.
Default LST Path: C:\Program Files\Bentley\ProStructures CONNECT for AutoCAD\AutoCAD 2019\Localised\English\PartList
3. Designer window get opens where we can customize the opened LST file.
NOTE: Before customizing, please Save As the LST file with different name to have a backup of the original LST file.
Here, you can customize the List (*.lst) file to print required partlist in ProSteel for AutoCAD.
