| Version(s): | through 08.11.13.140 | ||
| Area: | Database Platform Support | ||
| Subarea: | N/A |
Warning
The database version does not match the application. The version of the application is 'x.x.xx', but version of database is 'y.y.yy'.
Or
Database Version
Your database version [x.x.xx] does not match the application version [y.y.yy], would you like to upgrade your database?
Or similar message is displayed.
In [[Project Manager]], project icons are grayed out or have a red circle-slash symbol on them and the projects have no pages listed.
Each version of Promis.e and Bentley Substation (referred as "the software" for the remainder of this document) has its own corresponding project database schema, identified by a version number. The version number of the database is stored as an extended property of the Project table in SQL Server databases, and as a comment on the Project table for Oracle databases.
The error message occurs:
The version property can be of the database can be verified using the process described in [[10203|Error - No version resource could be located in database]].
See the [[Project Database Version - Promis.e]] or [[Project Database Version - Substation]] article to see which database schema versions are compatible with which application versions. Update the application or the database schema, whichever is older according to these articles.
Compressed database files have also caused this type of error message. SQL databases cannot operate if they are compressed.
[[Updating and Upgrading Promis.e]]
[[Updating and Upgrading Bentley Substation]]
[[Creating and Updating the Project Database]]
[[Error - No version resource could be located in database]]
[[Troubleshooting Project Database Connection Problems]]
| Original Author: | Matt_P |
