| Version(s): | through 08.11.12.73 | ||
| Environment: | Oracle | ||
| Area: | Database Platform Support | ||
| Subarea: | N/A |
Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue.
The 'OraOLEDB.Oracle' provider is not registered on the local machine.
Start a command prompt as an Administrator.
Change directory to the Oracle Home > \BIN directory. For example:
cd \oracle\product\11.2.0\client_64\BIN
Register the .DLL. For example:
regsvr32.exe OraOLEDB11.dll
Start a Command Prompt as an Administrator
| Original Author: | Matt_P |
Keywords: parts database
