| Product(s): | Promis.e | ||
| Version(s): | 08.11.07.xx | ||
| Area: | Project Management | ||
| Subarea: | Project Manager |
When attempting to create a new project, the following error occurs:
Internal Error
Error Message: Object reference not set to an instance of an object.
TargetSite: Void .ctor (ECT.ECAD.UI.CommandCarrier)
DeclaringType: ECT.ECAD.UI.DProject
Attributes: public
MemberType: Constructor
Existing projects can typically be opened without error.
Close Promis.e
Delete or rename the folder described in [[Application Data (per-user configuration) - promis.e]]
Restart Promis.e
| Original Author: | Matt_P |
Keywords: ECT.ECAD.UI.DManager
P/S: 36087, 500000062830
