| Version(s): | through 08.11.13.140 | ||
| Area: | Project Management | ||
| Subarea: | Project Manager |
The "Folders" directory tree area of the [[Project Manager]] is blank, showing no drives, folders, or projects.
Close the software.
Delete or rename the user application data folder:
[[Application Data (per-user configuration) - promis.e]]
[[Application Data (per-user configuration) - Substation]]
| Original Author: | Matt_P |
Keywords: missing, empty, white, explorer
P/S: 49711, 500000074037
