| Version(s): | through 08.11.13.140 | ||
| Area: | Project Management | ||
| Subarea: | Project Manager |
Various undesirable behavior is seen in a project including
Behavior may only affect certain pages and new pages typically behave correctly.
These behaviors are consistent with having one or more pages "offline" in the project. Data for the content of offline pages does not exist in the project database and so the symbols and wires on such pages do not behave as they do on online pages.
The problem behaviors are often discovered after upgrading the software since offline pages were not treated correctly in versions prior to V8i SELECTseries 3, behaving in many aspects just like online pages.
To make a page online, right-click the page in [[Project Manager]] and set the Set page online check box.
To quickly see which pages are online or offline in a project, use [[Run Reports]] to run the "Page List - Letter" report, which includes an "Online" column.
| Original Author: | Matt_P |
Keywords: attribute, AutoWireNumber, Assign Wire Number, Edit Wire Number, Manual Wire Number
P/S: 48336, 500000073168
