Product(s): | Promis.e, Bentley Substation | ||
Version(s): | 08.11.13.52 - 08.11.13.140 | ||
Environment: | N\A | ||
Area: | Installation_Configuration | ||
Subarea: | N\A |
How can I specify which Setup Configuration to use when starting the software?
Beginning with SELECTseries 8, an optional command-line switch has been added that is used to specify which setup configuration the software should use.
When the switch is not included when the application's executable is run, the software will use the most recently used setup configuration.
As an example, the following procedure will create two desktop shortcuts, one to start Promis.e with the "ANSI-IEEE Default" setup configuration and one to start Promis.e with the "IEC Default" setup configuration. The procedure can be adapted to Bentley Substation.
Right-click one of the desktop shortcuts and select Properties.
Select the General tab and change the name to "Promis.e SS8 IEC"
Select the Shortcut tab.
The Target field should contain something like the following:
"C:\Program Files (x86)\Bentley\Promise V8i\Promise\Promise.exe" "C:\ProgramData\Bentley\Promise V8i\Config\Ecad.dgn"
Add a space to the end followed by "-W@IEC Default" so that it looks like:
"C:\Program Files (x86)\Bentley\Promise V8i\Promise\Promise.exe" "C:\ProgramData\Bentley\Promise V8i\Config\Ecad.dgn" "-W@IEC Default"
Click OK.
Right-click the other desktop shortcut and select Properties.
Select the General tab and change the name to "Promis.e SS8 ANSI"
Add a space to the end followed by "-W@ANSI-IEEE Default" so that it looks like:
"C:\Program Files (x86)\Bentley\Promise V8i\Promise\Promise.exe" "C:\ProgramData\Bentley\Promise V8i\Config\Ecad.dgn" "-W@ANSI-IEEE Default"
Click OK.
If the "Promis.e SS8 IEC" shortcut is double-clicked, Promis.e will start and be set to use the "IEC Default" setup configuration. If the "Promis.e SS8 ANSI" shortcut is double-clicked, Promis.e will start and be set to use the "ANSI-IEEE Default" setup configuration.
How to create a desktop shortcut for an Office program or file - This can be applied to any application, not just Office applications.
