Blank, gray project pages
 Product(s):Promis.e, Bentley Substation
 Version(s):through 08.11.13.140
 Environment:N/A
 Area:PowerPlatform Support
 Subarea:N/A
Problem Description
After opening a project page there is no drawing area, it is just a gray, blank area.
Reason
All the Views are toggled off.
Steps to Resolve
  1. After opening the page, look near the bottom of the screen. There should be several small buttons numbered 1 through 8.
    If you do not see the view toggle buttons, select Tools > Views > View Groups > Open As Toolbox.
  2. Click the 1 button to turn on View 1.
If the page reverts to having no views enabled when it is reopened, enable View 1 once again then select File > Save Settings.
How to Avoid
Do not attempt to close pages by clicking the X button in the upper right of the design area.  This closes the view but does not close the DGN file.
The proper ways to close a page include the following:
 Original Author:Matt_P
Keywords: empty, grey, window, does not, cannot open, display
