|   | Product(s): | Promis.e, Bentley Substation |  |
|   | Version(s): | through 08.11.13.140 |  |
|   | Environment: | N/A |  |
|   | Area: | PowerPlatform Support |  |
|   | Subarea: | N/A |  |
Frequently used actions or toggles can be assigned to function keys for convenience.  As an example, this article describes how to assign the following actions to function keys, which can be particularly useful for users switching from AutoCAD based applications.
- F3: Toggle Accusnap (equivalent to OSNAP)
 - F7: Toggle display of grid
 - F8: Toggle Orthogonal locks
 - F9: Toggle snap to grid
Method 1
Select Workspace > Function Keys from the main pull down menus of the application.
Select the row corresponding the function key to be changed.
Enter the key-in into the Action field, press Enter.
    For F3: ACCUSNAP TOGGLE
    For F7: ECAD EXEC SHOWGRID
    For F8: LOCK=AX
    For F9: LOCK=GR
Click OK.
Method 2
- For Promis.e V8i open the following file in Notepad:
[[Program data folder - Promis.e|Program Data]]\WorkSpace\Interfaces\Fkeys\funckey.mnu
For Bentley Substation V8i open the following file in Notepad:
[[Program data folder - Substation|Program Data]]\WorkSpace\Interfaces\Fkeys\funckey.mnu
 - Change the highlighted lines to the text shown:
$FK5.0$ 10/4/2005 3:59:22 PM
301,help
302,task menu
303,Accusnap toggle
304,inputmanager currenttask
305,dialog viewsettings popup
306,dialog namedviews
307,ECAD EXEC SHOWGRID
308,Lock=AX
309,Lock=GR
30a,dialog toolsettings
30b,accudraw dialog
30c,inputmanager home
1301,inputmanager popupitem attributes,1
1302,inputmanager popupitem attributes,2
1304,inputmanager popupitem attributes,4
1303,inputmanager popupitem attributes,3
1305,inputmanager popupitem attributes,5
1306,inputmanager popupitem attributes,6
1307,inputmanager popupitem attributes,7
1308,inputmanager popupitem attributes,8
1309,inputmanager popupitem attributes,9
130a,inputmanager popupitem attributes,10
b01,inputmanager popupitem primary tools,1
b02,inputmanager popupitem primary tools,2
b03,inputmanager popupitem primary tools,3
b04,inputmanager popupitem primary tools,4
b05,inputmanager popupitem primary tools,5
b06,inputmanager popupitem primary tools,6
b07,inputmanager popupitem primary tools,7
b08,inputmanager popupitem primary tools,8
b09,inputmanager popupitem primary tools,9
b0a,inputmanager popupitem primary tools,10
b0b,inputmanager popupitem primary tools,11
b0c,inputmanager popupitem primary tools,12
 - Save the file.
 - Restart the software.
[[Platform Fundamentals for promis.e Standalone Users]]
