| Product(s): | Promis.e, Bentley Substation | |
| Version(s): | 08.11.12.137 | |
| Environment: | N\A | |
| Area: | PowerPlatform Support | |
| Subarea: | Manipulate Tools | |
Problem Description
When I try to move a symbol on a page, only the text moves and the graphics remain in the original position.
Steps to Resolve
- Select Tools > Levels > Level Manager from the main pull down menus.
- Right-click any column header on Level Manager and enable the Lock column.
- Locked levels will have a padlock icon in the Lock column. Unlock every level except for the following levels which should remain locked:
ECT_PAGE_TITL_GRAF
ECT_PAGE_TITL_LOGO
ECT_PAGE_FRAME
ECT_PAGE_LADD
ECT_PAGE_LINENUMBER_REGION
ECT_PAGE_LINENUMBER_TEXT
ECT_PAGE_ZONE_REGION
ECT_PAGE_ZONE_TEXT
- Try to move the symbol.
- If the symbol still does not move, modify it in [[Create Symbol]] and ensure none of the elements are on any of the levels listed in step 3, which are reserved for title block and page format use. Element Information (CTRL+I) and Change Element Attributes (Tools > Properties > Change Attributes > Change Element Attributes) can be used to move elements to other levels. Symbol geometry is usually on the ECT_DGRM_GRAF level.
