Document Type: TechNote
Product(s): Drawing Flattener
Version(s): 08.09.02.02, 08.09.03.30, 08.11.05.36
Original Author: Bentley Plant Technical Support Group; Richard DeLong
When running Flattener, if the current layer is locked, flattener will not flatten the drawing. It will run, but place nothing from model space into the flattened drawing. This applies to all versions of Drawing Flattener, be it XM or V8i.
To fix this issue, make sure that the current layer is not locked. It usually is a good idea to use the 0 layer as your current layer and leave it unlocked, since most AutoPLANT programs don't typically write to the 0 layer.
