Product(s): | Promis.e, Bentley Substation | ||
Version(s): | 08.11.12.xxx | ||
Environment: | N/A | ||
Area: | Installation_Configuration | ||
Subarea: | N/A |
Internal Error
Error Message: Data at the root level is invalid. Line1, Position 1
Targetsite: VoidThrow(system.exception)
DeclaringType: System.Xml.XmlTextReaderImpl
Attributes:Private
MemberType: Method
Undetermined. The software, perhaps due to insufficient permissions of the user, may be This can occur when there is incomplete xml data in the catalog.mdb file.
[[Rebuild Catalog|Rebuilding the catalog]] that contains the symbol typically resolves the issue. If rebuilding the catalog does not help, the problem could be with symbol in a different catalog. Try rebuilding the other catalogs seen in Catalog Manager.
Original Author: | Bhargav |
