| Product(s): | ProSteel | ||
| Area: | MicroStation CONNECT Edition Basics | ||
| Subarea: | LInes | ||
This wiki explains how one can divide a line into equal segments.
1. Type Facet in the Search Ribbon and open it.
2. The Facet Curve dialog opens up, set the below settings as shown in the image below.
3. Now, select the line and accept it (left-click). With this, you will divide the line into equal parts as shown in the below image.
