| Product(s): | AutoPLANT Isogen | ||
| Version(s): | 08.11.XX.XXX | ||
| Environment: | Windows 7 64/32 bit | ||
| Area: | Configuration | ||
| Subarea: | |||
| Original Author: | Abhijit Bute, Bentley Technical Support Group | ||
Error or Warning Message
One of the project gives this error when generate isometric through Isogen.
Refer following steps to resolve this issue.
1. Open the file C:\Program Files (x86)\Bentley\Plant V8i\Modules\Base\PCF.INI.
2. Add PWF = SW under the section [MAP_ENDCOND4SKEY] as shown below:
<C R>[MAP_ENDCOND4SKEY]
SCF = SC
SCM = SC
SWF = SW
SWM = SW
SOF = SW
BW = BW
BV = BW
FL = FL
FLL = FL
PWF = SW
3. Save and close the file PCF.INI.
4. Run Isogen.
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
