Applies To | |||
Product(s): | OpenPlant Isometrics Manager | ||
Version(s): | 08.11.09.440 & Above | ||
Environment: | Windows 7 64 bit & Others | ||
Area: | Settings/Attributes | ||
Subarea: | |||
Original Author: | Rahul Kumar, Bentley Technical Support Group | ||
In OpenPlant Isometrics Manager, Spec Breaks appearances are in general discussion to show it up in isometrics drawings. Various requisition has been made to describe the change of spec in iso drawings based on project utilities and also based on different specs or to show few specs in particular. Below description highlights managing spec breaks with few use cases. To note, this has been added recently from the version mentioned in template above.
A. To Toggle off all Spec Breaks in OPIM
B. To remove few Specs in an isometric Drawing.
communities.bentley.com/.../22225.removing-spec-break-symbol-in-isometric-drawing
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
