| Product(s): | ProSteel | ||
| Area: | Detail Style | ||
| Subarea: | Dimensioning tab | ||
When detailing shipping elements, additional axes appear in the holes of the plate which are marked with a red arrow in the below image. Where in detail center standard can we turn off the display of these axes?
Enter methods to resolve in this section.
1. Preview the drawing and open Edit Detail Style.
2. Go to Dimensioning > Common > Miscellaneous and under the Gusset Plates section uncheck the option With System Axis and then update the preview.
In this way, the axes lines of the holes will disappear from the drawing as shown in the above image.
