How to draw 3 Phase Wire - OpenUtilities Substation
 Product(s):OpenUtilities Substation CONNECT Edition
 Version(s): 10.00.XX.XX to 10.09.XX.XX
 Environment:NA
 Area:Wiring Features
 Subarea:NA
Background:
The 3 Phase Wire tools help users to draw three wires at a time simultaneously.
1. Select 2D Design >> 3 Pase Wire under the Wiring section.
2. Follow the below short video for how to draw a 3phase wire in OU Substation .
Note: As highlighted in the above case the wire will be connected differently depending on which phase is chosen as an ending point for the wire while routing. Also if in any case, the second phase is chosen the all the wires will connect to the second phase only.
 Original Author:Satish Saptasagar
