Bentley OpenUtilities Designer CONNECT Edition 10.05.00.05 Resolved Issues List:
ID | Title |
419112 | Attribute Relation rules not working at point WLs |
419111 | Unable to create single point path in offline design |
415285 | Cannot remove Global attributes in Job Defaults Assistant |
415267 | Unknown error in Job Defaults Assistant when updating Global attribute of type STRINGVAL |
384392 | Edit User from admin tool causes crash |
365639 | Run-time error during offline design for ribbon tools Place Path and Place Point |
322669 | Update to Work Request may cause invalid state change |
322651 | Eliminate the requirement to "Run as Administrator" |
293083 | Refresh issue on Cancel |
173289 | Load, DER Primary Location, and DER Secondary Location features lacking configuration |
173006 | Regression of Job Defaults Assistant issue with multiple Global attributes |
171288 | Cannot create Custom Cost |
160362 | Update to work Request or Design fails |
