| Product(s): | Bentley sisNET Multi Utility | ||
| Version(s): | 08.11.07.115 | ||
| Area: | Configuration | ||
| Subarea: | |||
| Original Author: | Andreas Becker, Bentley Technical Support Group | ||
Note: The order of the Edit PrintPreparationTexts-Dialog in sisNET is alphanumeric
If you want to force a certain sequence, the variables have to begin with a numeric setting, such as 01_Projectnumber, 02_Project, 03_Author ...
Configuration dialog:
Result at runtime:
