| | Product(s): | OpenUtilities Substation | |
| | Version(s): | 10.00.XX.XX to 10.10.XX.XX | |
| | Environment: | N/A | |
| | Area: | 3D Layout Features | |
| | Subarea: | Insert Cable/Bus Object | |
In Bentley Substation CE Update5 we introduced the ability to select unique phase levels for cables or bus so that they can easily be distinguished for clash detection purposes.
- Click Insert Cable/Bus Object 3D Design, select a cable, and click Insert to initiate the cable placement.
- Select the desired Phase Level from Placement Options dialog.
- Select the Hook points between to and from equipment between which Cable/Bus needs to be placed, and after selecting both the Hook point if using Hook point method for placing the cable Cable/Bus Setting dialog will appear and then click Ok after making required changes in the settings
Note: Specify the Sag Algorithm and other desired settings as seen in below Cable/Bus Object Setting dialog and then Click OK to the to complete the placement.
Alternative Steps to Accomplish
The Properties Control allows you to set a ‘Phase’ property which can be applied to any cable / bus that you insert while the Properties Control is running. The Phase you set in the Properties Control will drive the default Phase level in the Cable / Bus Placement Options dialog.
- Click 3D design -> Properties control and set the ‘Phase’ Property to the desired phase.
- Notice the Phase Level in the Placement Options dialog corresponds with the selected phase in the Properties Control by default. You can override the level if desired by selecting a different level from the picklist.
- Select the Hook points between to and from equipment between which Cable/Bus needs to be placed, and after selecting both the Hook point if using Hook point method for placing the cable Cable/Bus Setting dialog will appear.
- Specify the Sag and other desired settings and then Click OK to the Cable/Bus Object Settings dialog to complete the placement.
Note: If you want to visualize the phases in different colors you can set different colors for the levels or utilize the Thematic Manager.
| | Original Author: | Avanti Khandalkar | |
