Resolved issues in Promis.e CONNECT Edition Update 10, 10.10.00.53
Product:Promis.e CONNECT
Generation:CONNECT Edition
Version:
IDTitle
230927[Configuration Variables] Modify Catalog Paths -> Edit mode -> Append and Prepend doesn't work correctly
252074Destination attribute position on cable diagrams
252280[Forced Routing] enable Unforce for wire potential and potential group
253374Project Publisher: the name of the packing list created by the Project Publisher is misspelled
307890Memory Leak I Possible Memory leak while using different functions
311617[Open Page] Open page reports error when add one LCM custom attribute that assigned to Wire property Name of Current
477193[PW integration][Environment]Shows "Internal Error" when try to open read-only page from Project Manager
516510[Navigation] user defined modes are missing from navigation
522420[Wire Diagram][Terminal Symbol] terminal number attributes missing and not populating with correct values
527335[PW Catalog Manager]Delete a category, it popups unexpected dialog.
535355[Insert Symbol By Name] Fail to list catalogs added in Modify Catalog Paths with Edit mode Append/Prepend while Insert Symbol By Name
537759[Network Workspace][Rename Project] Rename one network project that has been opened one page by another user will report error
538898[Page Format Designer] It reports error when extract page format from the demo projects
548942[Configuration Variables] The user is not able to select WorkSet files in Configuration variables in Managed WorkSpace with PW
570805[Forced Routing] new function to allow user to unforce all connections in project
576971[New Project] An error appears when create a project under path defined by Add a network location
577159In correct terminal numbering on wire diagram
579263[Create Symbol]Create a symbol without device id, and then insert it, copy it, the CPs are not correct.
579461[Run Graphical Plan]It popups error dialog when place script for some special terminal in the DEMO project.
583176[Grid/Snap Settings] Grid value in Design File settings not maintained  if Enable Grid/Snap Lock option is unchecked in options
583548[Project Manager] Page preview is not updating
587866Symbol Graphics not Saved
596767[Wire Link] Wire Link's symbol text attribute cannot work properly
597173[Place Symbol Again] Error Message while using Place Symbol Again for Symbols without Device Tag/Installation / Location
597758[Page Management][Copy Page] Copy multi pages from one project to another project will occur error
601962[Update Project Database] Project Database cannot be updated using UI
613121[Restore Project] The database is not compatible when we try to restore a project to a database in another server instead of the Default Project Database one.
613417[Find-Replace Wire Property][Performance][PW] It takes about 4 min 50 sec to open the Find-Replace Wire Property dialog in large project
613682[Terminal/Pin-Plug Manager]It should have a vertical stroll bar in the left side if there are many terminals.
613683[Terminal/Pin-Plug Manager][PW][Performance]It is too slow to open Terminal/Pin-plug manager and click Apply button after add cable in the terminal/Pin-plug manager dialog.
613686[Performance] [PW]Rename Project is slow.
613745[Wire Manager][Performance] It takes more than an hour to make a force connection of wire in the Wire Manager in large project
613962[Project Publisher][ProjectWise] It reports exception about access pltcfg file during publishing in PW project.
615579[Copy&Move Objects][Copy page][Performance] It takes long time to copy multi objects and copy 3D Layout mode page
615624[Delete Objects] [Performance][PW]Delete multi 3D objects will takes long time
616480[Update Wiring Diagram][PW][Performance]It is slow to open update wiring diagram dialog.
617420[Performance][PW] Modify Project is slow.
617723[Rebuild Project Database] An error occurs when rebuild Project Database
617967[Page Copy][Forced Routing] new option to all user to Maintain all Forced Connections during page copy
627531[Backup] When a Project is backed up the Devinfo table details from Project DB are not present in the ECADProject.mdb file in the PRJ backup
631211[Title Block Designer] Options to select the Seed file before creating / editing a Title Block
633768[Page Copy][ProjectWise Integration] Illegal characters in path error appears for certain pages when user attempts to copy page
636805[Raster Manager][ProjectWise Integration] When a Page containing Raster TIF image attached is closed and reopened in raster manager the TIF file cannot be seen
645218[ProjectWise Integration][Configuration Variables] The user is facing the issue that if the Promise.cfg file contains the complete path for ProjectWise location of the configuration file
645434[Project Options][Command Protection] - Exposing Parts Database 'Show Differences' to all User Roles
646144[Catalog Manager] Getting UI error while rebuilding catalog
646416[Configuration Variables][Workset] paths in dialog do not match paths in Promise.cfg
646418[Configuration Variables][Workset] changing path value changes values in Workspace tab
652856[Performance] Promis.e doesn't release memory after closing page.
660036[Manage | Wiring Manager] Unforce Connection doesn’t work.
662092[Restore Project] Error message during project restore due to bad data in LCM_GraphicalObject table in database
667972[Memory leak]related with traversing selection sets.
680354[Project Manager]Imported drawing is blank
680363[Restore project] It cannot restore project from PW folder successfully for the second time
680390[Create Project] Create project will report error when fill out an non existent Project database
681907[Options][Display Formats][Cross Reference Format] Expression do not work due to variable translation.
681909[UI] The size of some control is too small to display the whole content.
682053[UI][Draw Ladder] The width of the dialog for setting the space between ladder lines is too small to display the whole caption.
682064[EDC] The text of ‘Orphaned Balloons’ in the Error Checking dialog is not localized.
682342[Report template designer] the attribute is not getting properly align
682517[Wire Diagram][Wire Number Attributes] value not updated when user deletes wire number from schematic
684891[ Symbol Cross Reference] Symbol cross reference visibility cannot be turned On/Off using Show Cross-Reference option
684942[Part Part Number Attribute] When the user updates symbol text the Part Part Number attributes disappears
686241[Memory Leak] Opening and closing results in extra processes running in Background
689888[Wiring Manager]The default wire potential tree view display is not correct.
690542[Wiring Manager]Force routing a connection, and clicking apply, then click OK button to close the wiring manager dialog, and reopen it again, the connection is not forced.
690553[Wiring Manager]Change the capital “Want” and “Unforce” to lower case letters “want” and “unforce”.
693509[Balloon Number Attribute] When the user updates symbol text the Balloon Number Attribute on NamePlate symbol disappears
693538[Restore Project][PW Integration] When user tried to overwrite an existing project in a project wise path using restore project the database details are not overwritten
699964[Copy Page] It reports error to copy page in some projects
701148[Settings][User Preferences] enabling Compress File On Exit option causes application to Not Respond when user switched from one page to another
701492[Wiring Manager]The potential group order should display like 1, 2, 3 … 11, should not like 1, 11, 2.
701507[Create Symbol]Modify terminal number, it cannot display in the drawing.
701519[Run Report]After force routing, the gauge and color cannot display in the wire list report.
702086[Wiring Manager Unforce Connection]Sometimes the unforce connection cannot unforce all the connections in the potential.
702266[Copy Page Maintain Forced Connections]Sometimes the forced connections display not correct in the copied pages.
703049[Installer] Failed to install
703166[Wiring Manager][Force Connection]Force several potential, and click apply button in the wiring manager dialog, some of them are not forced.
706960[Wiring Manager][Add Device]Add device in the wiring manager dialog, it popup error dialog when clicking Apply button.
709306[Open Page] DGN File name is changed to lower case when exported to PDF / Displayed
709942[Wiring Manager][Add Device]Add device in the wiring manager dialog, close the wiring manager dialog, and reopen again, the wire number does not display in the wiring manager dialog.
711516[Insert Cable/Bus] Placement by Path Method
713723[Wiring Manager] An error occurs when opening the Wiring Manager in large Project
714568[Device Usage Chart]Right click the Device Tag->click Device Usage Chart, it popups error dialog.
714586[Wiring Manager][Performance] It takes about 3 min 09 sec to open the Wiring Manager dialog in large Project
716141[Configuration Variables] Allow user to set the variable assignment level as Workspace and Workset level.
721679[PW Integration] Crashing due to background process
726268[Navigate][User Preferences] After set "Reset Pop-up menu" to Click in Preferences dialog, Navigate menu will list on the top of right click menu
726605[Insert Macro] Insert Macro “STR_MACRO” will crash to the desktop
728751[Copy Page] Equipment properties and wire tag in the copied page do not match the details from the source page
729740[Project Builder] It reports exception during creating project to include option item.
730001[Copy Objects] Copy objects will crash in the demo project
730701[Project Builder] It reports Page Error after we click Create button.
731424[RebuildProjectDatabase] An error occurs when run the Rebuild Project Database for user project
732820[Device Usage] incorrect I/O Address and Function Text values displayed in device usage chart
732916[PLC Address and Function Text] plc child address and function text values do not match parent values after using Device Usage to change child position
733161Slow performance of Switch the page
733648[Performance] [New Page] Open New Page dialog and the 1st time New Page is obviously slower than that in the last release.
734470[Copy Page][Copy Circuit] An error occurs when copying a circuit on copied page
735620[Navigate][PW]Navigate from a new created mode to another new created mode, and then navigate back, and navigate back again, the software will crash.
737052[Thematic Manager] The created Thematic does not work after clicking the Apply button.
738784[Configuration Variables]Fail to list Path in Create Catalog dialog for default WorSet, ANSI-IEEE Example and IEC Example
738891[Memory Leak]The memory increased after running MVBA in MicroStation.
739425[PW Explorer Plug in] An error occurs when copying a page with symbols/wires from PW Explorer
744028[Copy page][Copy circuit] It reports error or crash when copy some circuit on the copied page
744288[Wire Diagram]Create wiring diagram symbol, defined it Parent CPs, and add Wiring Number attributes, It pups error dialog when update the wiring diagram page with this symbol.
744955[New Page]The page description cannot display in the drawing using default workspace.
748882[Install] Fail to install due to failing to install Microsoft Visual Basic for Application 7.1
757020It reports unexpected warning during launching software due to wrong Page  Templates setting.
757096Certify the latest ProjectWise Explorer release 10.00.03.453
760389[Multi-DB]The software will get the wrong project database if we reference a page from another DB server.
763011[Start Software] It failed to restart software
767868[Symbol Create Wizard][Place Connection Points]Clicking Place button reports error.
771067[Restore Project] Cannot restore some user projects
774887ConfigurationManager.GetVariable() function returns NULL
774930[PW]After office update, the cannot launch correctly when connecting with PW.
776249[Modify Page]In the Modify Page dialog, deselect the toggle “Place  title block in sheet model”, it should popup warning dialog.
776771[Insert Objects] [Symbol Settings] Click Symbol Settings in Insert Symbol/ Macro dialog reports error
805305Add the variable _USTN_CLOSE_DESIGN_CHANGINGFILES = 1 in promise.cfg
807028[Shortest Distance Routing] [PE Project] The software will automatically be closed when executing the Shortest Distance Routing onuser project
809405[Ribbon] Display commands and mode type show wrong
811317Can't load Project Manager properly from drawing view after we click File > Close
823097[Project Management] After draw a wire without targets, switch page with wire link reports error
