| Product(s): | ProStructures (ProSteel) | ||
| Area: | Import/Export | ||
| Subarea: | Export DWG | ||
This wiki explains how one can export a dgn file to an older version of DWG.
1. Go to backstage File and select Save As.
2. Set the Save as type to DWG format and left click on the Options button.
3. In Save As DWG/DXF Options dialog, go to General > Basic > DWG Version here you can set your required DWG version to save. Once done click on the OK button.
4. Now, click on the Save button to export/save a dgn file to a set dwg file.
In this manner, we can export a dgn file to an older version of DWG.
