| ADO ID | TITLE |
| 624496 | [PW][Run Graphical Plan]It popups error dialog when run graphical plan in user env with the attached project. |
| 732342 | [Copy Page][PW] An error appears when copy page to a project with Save pages in drawing set subfolder checked ON |
| 741077 | [BOM Manager] It cannot show nameplate symbol's part number on drawing |
| 743386 | [BOM Manager]Add device with three part number, and change the Primary part number in the Select Part Number dialog, two part number display as Primary. |
| 792063 | [BOM Manager][Nameplate] It cannot load the nameplate attributes from BOM Manager to drawing when insert nameplate symbol by device ID |
| 799430 | [Autobackup] DeviceDB Error Message "BackupPrjDataWow6432 error: 9764" |
| 871969 | [Insert Din Rail]It popups error dialog when clicking Insert Din Rail. |
| 880415 | [Replace Family]It cannot list all the families in the catalog in the Replace Family dialog. |
| 880426 | [Update Family]It popups error dialog clicking the Get Family list in the Update Family dialog if the project has symbol inserted with a family. |
| 888717 | [BOM Manager]Add a device with three part numbers, and set different other data, and then move from workorder node to revision node, the values for the other data are missing. |
| 890505 | [Update Page] Update page does not regenerate the missing nodes on the wire |
| 891372 | [BOM Manager][Copy Page]Drag a symbol from Unassigned items to a BOM->Revision->Work Order node, and then copy the page to a new project, the symbol text is not maintained. |
| 891913 | [Balloon]Move the balloon callout->modify balloon values, the balloon position changed. |
| 895693 | [Copy Balloon]Copy a page with symbol duplicate with the symbol in the target project, the balloon callout inserted by device is not correct. |
| 901315 | [Place Balloon]It crash or popups error dialog when deleting the balloon number in the Place Balloon dialog and then click a point in the drawing. |
| 904192 | [Wiring Manager][Forced Connection] In Wiring Manager when Connection point sequence is changed the Wire Properties like gauge and color are deleted |
| 904913 | [Catalog.mdb]If the Catalogs are located in Network location the Catalog.mdb cache files if deleted are not regenerated |
| 914031 | [BOM Manager] The quantity for a Item number is not displayed correctly in the BOM Manager |
| 928371 | [Network Projects] An error message occurs when multiple users select the same project |
| 931615 | [BOM Manager][Balloon Number] Internal Error "These columns don't currently have unique values." appears when BOM Manager > Balloon Number contains SPACE " " at the beginning or end |
| 939449 | Substation( BOM manager):- Internal error message "These columns don't currently have unique values |
| 960346 | [No Access DB Engine]The software will pop up an exception issue after closing Substation. |
| 963434 | [Thematic Manager][Apply Thematic] Thematic display does not work with MicroStation Objects |
| 964596 | [Configuration Variables] After save catalog path setting, all other variables settings will be changed back to default setting in Configuration Variables dialog |
| 964734 | [ProjectWise Integration][Network Catalog] It cannot remember catalog order for network path in Configuration Variables dialog |
| 965180 | [Thematic Manager][Apply Thematic] Thematic Display does not work if symbol created using Save as Shared Cell option |
| 966184 | [Network WorkSpace] Fail to launch software with network WorkSpace with the warning of "Common data folder does not exist" |
| 980922 | [Configuration Variable][Catalog]The catalog path set in Modify Catalog Paths can’t return to ELEC_CATALOG_PATH for WorkSet Level in Configuration Variable. |
| 982768 | [PLC Generator]PLC generator->Generate->All->click OK button, it popups error dialog. |
| 988710 | [Catalog]Rebuild IEC catalog ‘AB-MET’ reports error. |
| 993147 | [Options]Components Center is disappeared in Options in Substation U14 and Promis.e U12 |
| 994401 | [Publish iModelHub]Cannot publish 2D schematic page successfully. |
| 1003898 | [PW_Configuration Variables] An error appears after change ELEC_SYSTEM_OPTION_PROFILE value and click OK in Configuration Variables with ProjectWise data source |
| 1013342 | [Thematic Manager] It cannot remember thematic data in Thematic Manager with some restored projects |
| 1022689 | [BOM Manager] Drag some part items to different node tree will report error in BOM Manager |
| 1029461 | [Configuration Variables] Modify Catalog Paths -> Edit mode -> Append and Prepend doesn't work correctly |
| 1029699 | [Restore Project] Error message during project restore user's project "Column 'daName' does not belong to table My Tabe" |
| 1031578 | [Publish iModelHub] Cannot publish user project to iModel server |
| 1031639 | [Insert Symbol By Name] Fail to list catalogs added in Modify Catalog Paths with Edit mode Append/Prepend while Insert Symbol By Name |
| 1047589 | [Wire Label][Data Manager]When the user updates wire tag for a wire label in Data Manager the tag is duplicated to all other blank wire labels in the project |
| 1048035 | [Data Integrity][Wire Label] wire number exists on drawing but missing from user interfaces & project database |
| 236424 | New Configuration Option allowing administrators to abandon MS Access DB files for: Multi_Language_UI.mdb for Mode/Dialog texts/Language phrases/Attributes. |
| 252341 | Would like to abandon using MS Access databases (.mdb) for symbol catalogs. |
| 748387 | [Print Organizer] Selecting multiple pages in Project Manager and send them directly to Print Organizer |
| 815588 | [Data Integrity]When a project page dgn is deleted from the project folder the page is still displayed in the Project Manager after Rebuild/Backup/Restore project |
| 894393 | [Place Balloon][Text Rotation] add option to allow user to Place Balloon texted rotated |
| 923681 | [PW Integration] [Page Management] It should implement correct pw user Read permission with Page Management commands |
| 923867 | [PW Integration] [Project Management] It should implement correct pw user Read permission with Project Management commands |
| 987899 | [Build upgrade]iModelBridgeFwk.exe needs to upgrade to the new version that was used by PowerPlatform U17. |
| 993164 | [Remove Multi_Language_UI.mdb]Support to check ELEC_Language_DB_Path as a folder if txtMultiLanguage=0. |
| 993296 | Provide a tool to generate txt files from Multi_Language_UI.mdb and catalog.mdb. |
