| Product(s): | ProSteel | ||
| Area: | Navigation Tools | ||
| Subarea: | Select View | ||
This wiki explains how one can edit the Workframe Properties. There are three ways to open and edit the Workframe properties and these are as follows.
A. From Select View dialog.
B. From Context Menu
C. Double Click
A. From Select View dialog:
1. Open the Select View tool located at View > ACS View > Select View.
2. In the Select View dialog, select the Workframe that you want to edit the properties and then select the Edit Workframe button.
3. The Workframe Properties dialog opens, here one can edit the required properties. (Refer the image from Step C-1).
B. From Context Menu:
1. Select the Workframe grid, hold right click and from the context menu left click on Structural Properties.
2. Now, the Workframe Properties dialog opens for editing. (Refer the image from Step C-1).
C. Double Click:
1. Just double click on the Workframe grid to open the Workframe Properties directly and can edit it as required.
In this way, one can edit the Workframe Properties.
