Applies To | |||
Product(s): | OpenPlant Modeler | ||
Version(s): | 08.11.09.xxx(SS5) / 08.11.11.87(SS6) | ||
Environment: | Windows 7 (64 bit) | Windows 8 | ||
Area: | Component | ||
Subarea: | Data - Bolts-Spec Grids - Query | ||
Original Author: | Rahul Kumar, Bentley Product Advantage Group | ||
To select correct set of bolt length in spec grid after calculation in OpenPlant Modeler.
In OpenPlant Modeler, while querying the bolts during modeling a flanged type components, it displays list of Bolts to select in spec grid as per calculated length it suits to. User was under impression that it should list out all the data entered in spec with all possible types in spec grid.
In user spec, for Bolt lengths which are failing to accompany the minimum calculated length does not show inside the spec grid. For example, there were 4 different length available in spec for a size, say 108, 121, 133, 238 and minimum length required calculated as 110. In result to it, displays only 3, i.e. 121, 133, 238 and left length 108, which was shorter than the minimum calculated length. Check below example.
In Spec:
In Spec grid while placement:
See below step to describe the explanation of placement criteria.
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
communities.bentley.com/.../14484.how-are-bolt-lengths-calculated-in-openplant-modeler
Bentley's Product advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
