The table below lists the fixes and enhancements in sisNET CONNECT Edition Update 4, with version number 10.07.04.01, released on July 29, 2021. Update 4 was built on PowerPlatform 10.15.1 and OpenCities Map 10.7.1.
| ID | New | Change | Bug | Description |
| 419353 | X | sisNET: the crash when calling the object history of an object via the object info is now fixed. | ||
| 624880 | X | sisNET: the job name can now be up to 50 characters long (via the direct dialog box) | ||
| 670507 | X | sisNET: Fixed the crash when moving a view. | ||
| 670539 | X | sisNET: Both the sisNET and Platform version numbers are now available with the new 'Version Info' button in the ribbon under Administration. | ||
| 555987 | X | sisNET: The incorrect parameter processing when sending the "VIEW ZOOM" key-ins has been corrected. | ||
| 630738 | X | sisNET: the length of SQL commands in macros (OPENCURSOR, EXECSQL, QUERY) is no longer limited to 256 characters | ||
| 546658 | X | sisNET: The sisNET user and administration manuals can now be accessed via the "Pdf-Dokus" button in the sisNET Ribbon under Administration. | ||
| 446525 | X | sisNET: The error when importing a configuration of the HR module was fixed. | ||
| 636817, 501542 | X | sisNET: Elements created with a self-defined line style will be displayed with a correct line style even after saving the job. | ||
| 652210 | X | sisNET (EN Version): opening a DGN file (double click) with the OUSisnet EN version is now correctly licensed considering the SISNET_LICENSE_PRODUCTS variable. | ||
| 467415 | X | sisNET: texts in SAP dialogs are now displayed in the correct language | ||
| 370134 | X | sisNET: When moving a dimension line, its original priority and transparency are preserved. | ||
| 646630 | X | sisNET: When moving the view, not all objects were displayed in some cases despite automatic view refresh. This error has been fixed. | ||
| 596936 | X | sisNET: The error message when opening the "Preferences" dialog in the Backstage area under "Settings" no longer appears. | ||
| 630723 | X | sisNET: The PrintPrep default PDF plot driver (MS_GEOPRINTPREP_PDFPLOTCFG=$(MS_GEOPRINTPREP_DEFAULTS)PrintPreparationPdf.pltcfg) has been replaced with the PowerPlatform default PDF plot driver (MS_GEOPRINTPREP_PDFPLOTCFG = $(MS_PLTCFG_PATH)pdf.pltcfg). The default PDF plot driver is used by the 'Create PDF' command (printpreparation workflow savepdf). | ||
| 616391 | X | sisNET: The obsolete entry 'Search by predefined object query' has been removed | ||
| 631236 | X | sisNET: Objects were sometimes not displayed when the view was rotated. The error is now fixed. | ||
| 631542 | X | sisNET: The call of the EXECSQLFILE macro with an incorrect file path was corrected. | ||
| 618522 | X | sisNET: The call of filter libraries with two-digit IDs was corrected | ||
| 627151 | X | sisNET: The LicenseStatus_Limited (after more than 7 days without CC login) is now handled correctly. | ||
| 560949 | X | sisNET: The tooltip of the dialog for selecting the category is now displayed in the correct language | ||
| 556221 | X | sisNET: In the task sisNET-Tools 'Annotation' the entries have been corrected | ||
| 501439 | X | sisNET: The image composition after zooming several times and with many references has now been improved. | ||
| 618284 | X | sisIMS engine: The causes of crashes related to referenced raster files have now been eliminated. | ||
| 556430 | N_SYS_FEATURE_STYLES Update to support further tests | |||
| 608042 | X | sisNET: When capturing a standard station/standard KVS using prototyp.ma, the labels of the ST connection points are now generated correctly. The error was that in previous versions the DAS type of the prototype object types was copied incorrectly. | ||
| 580450 | X | sisNET: The WORK FENCE DKOPIEREN command - copy and scale fence content and add as object part - works again. | ||
| 603570 | X | sisNET: The use of the wrong font type when placing dimensions using the netdim module has been corrected. | ||
| 98448 | X | sisIMS Desktop: The 'Coordinate Center' fields now allow input and thus map navigation by coordinate input. | ||
| 597516 | X | sisNET: The task control dialog is always loaded at startup. If this is not desired, loading can be switched off by setting the environment variable SISNET_LOAD_TASKNAVIGATION=0. | ||
| 534695 | X | sisNET: The sisNET Performance Tool has been added. The call can be found under Administration in the sisNET Ribbon. | ||
| 553152 | X | sisNET: after the command 'Copy view' the target view is now updated. | ||
| 539000 | X | sisNET: During ASCII import, macros for existing objects that needed to be updated were not executed correctly. The error is now fixed. | ||
| 572819 | X | sisNET: When updating the maps in Explorer, it sometimes crashed if the MicroStation reference dialog was open at the same time. As a workaround, the dialog is now closed before updating. | ||
| 598534 | X | sisNET: The creation of parallel lines with a given distance is possible again with the user module UMLIN. | ||
| 450706 | X | sisNET, sisFLOW, sisVIEW: The context menu has been revised. | ||
| 596901 | X | sisIMS: obsolete Geotools.dll removed by Setup | ||
| 595219, 489288 | X | sisNET: The names of the custom line styles are now correctly stored in the feature style table. | ||
| 538673 | X | sisNET: for the display of the element info of a dimension object, the properties dialog is now used | ||
| 552336, 517518 | X | sisNET: The functions: Copy or move parallel, Delete vertex and Change element attributes have been unlocked in sisFLOW | ||
| 542572 | X | sisNET: The error in the length calculation of the CALCPARTLENGTH macro function for a line with only one point has been corrected (correct result: length = 0). | ||
| 539200 | X | sisNET: The fence settings in FILTER module are now handled correctly. | ||
| 583542 | X | sisNET: plotting with views/themes other than view1 now works again. | ||
| 550285, 578147 | X | sisNET: The tray module call by means of RUNMDL macro was corrected | ||
| 99196 | X | sisIMS Desktop: The list of output formats (graphics export) has been extended with DWG, DXF. | ||
| 580845 | X | sisNET: The permissions of CAD elements are now taken into account when saving a job |
