The table below lists the fixes and enhancements in sisNET CONNECT Edition Update 3, with version number 10.07.01.01, released on April 9, 2021. Update 3 was built on PowerPlatform 10.15.1 and OpenCities Map 10.7.1.
| ID | New | Change | Bug | Description |
482822 | X | sisNET: The function "Display constraint" has been corrected. | ||
491594 | X | sisNET: It is possible again to move orthogonal dimensions using the "Move object" function. | ||
492665 | X | sisNET: When opening a job (via job manager) from another commodity, the commodity list is now correctly synchronized. | ||
492665 | X | sisNET: The commodity list in the ribbon now reacts correctly to the job change. | ||
499625 | X | sisNET Tools: The errors when starting the database update when using the actions AKTION_TEIL_MOVE_VERTEX, AKTION_TEIL_DELETE_VERTEX, AKTION_TEIL_INSERT_VERTEX in the action info block of the object descriptions in the configuration have been fixed. | ||
500774 | X | sisNET: Active filters are taken into account again when plotting. | ||
501542 | X | sisNET: The error when creating orthogonal dimensions with user-defined line types has been fixed. | ||
504679 | X | sisNET, sisFLOW: The MicroStation Mirror function can now also be used for CAD graphics if no element has been selected beforehand. | ||
507543 | X | sisNET Tools: The error when creating the tables of an object type newly inserted in the configuration has been corrected. | ||
511421 | X | sisNET: The incorrect length specification of the variable _LAENGE when creating objects with multilines has been corrected. | ||
517991 | X | sisNET Tools: The "Text" column of the table N_FS_OBJ_MAKRO_ZEILE has been extended to 1000 characters. | ||
518152 | X | sisNET: The bug when moving sisNET objects using a fence was fixed. | ||
519426 | X | sisVIEW: The automatic view centering based on a GPS location works again. | ||
520583 | X | sisNET: The Objecteditor mask disappears after the first mouse movement if the Objecteditor was opened by double-clicking on an object. The Form mask is not affected. This problem has been resolved. | ||
521114 | X | sisNET: The coordinate error when creating an object using the UMLFC module has been corrected. | ||
522995 | X | sisNET: The log when repairing a pool file is now given the correct name. | ||
522996 | X | sisNET: The progress when checking pool files in case of checking several files is displayed by progress bar and an improved message in the message window. | ||
524874 | X | sisNET Tools: The problems of the database update on AZURE VMs with spaces in the installation path have been fixed. | ||
525585 | X | sisNET: The crash when changing topics in Explorer and triggering the "Update content by view range" function after a DWG export via the fence function has been fixed. | ||
527413 | X | sisNET: The export of the current job did not take into account the objects deleted in the job. This has been corrected. | ||
528009 | X | sisNET: The annotation was not adjusted when a annotation-relevant attribute was emptied. This has been corrected. | ||
528023 | X | sisNET: The creation of construction points with dimensions works again. | ||
530475 | X | sisNET: The crash when using the annotation mode 51 - BMOD_LEADER_LINE - has been fixed. | ||
| 531196 | X | sisNET: When placing annotations using mode 12 (labeling at a fixed distance along a line), the incorrect calculation of the insertion point when placing along a multiline has been corrected. | ||
531562 | X | sisNET: The filter call from Explorer has now been corrected. | ||
531677 | X | sisNET: When starting sisNET, BentleyMap is no longer automatically loaded. If BentleyMap is required, it can be started by setting the variable BENTLEY_MAP = 1 in sisstart.cfg or datenbestand.cfg. | ||
531854 | X | sisNET: The error when importing files generated by the FME plugin ( token = Angle, syntax error, unexpected IDENT) has been fixed. | ||
532294 | X | sisNET: AccuDraw now remains active when drawing the baseline of a dimension. | ||
533244 | X | sisVIEW: Functions of the Forms mask - open external documents, display graphics, display value tables, output of data - has been reactivated in sisVIEW. | ||
533332 | X | sisNET: Changes to CAD elements with MS tools no longer detach the sisNET link. | ||
537104 | X | sisNET: The object editor scripting was reactivated. A CodeDom-based script engine was implemented as a replacement for the no longer available VSA ScriptEngine. The old scripts created in VisualBasic .NET can still be used. | ||
544055 | X | sisNET: Attaching a reference file with the REFATTACH macro function has been revised: - It is no longer possible to reference the same file twice - Attempting to reference a nonexistent file issues a MessageCenter warning - The name of the file to be referenced can contain $ () expressions | ||
544056 | sisNET: The .NET exception that occurred in Explorer due to multiple referencing of the same file has now been resolved. | |||
544198 | X | sisNET: The error that occurred when the objects were selected individually via spatial selection when the context menu command "Send to selection tool" was executed on an object before has now been corrected. | ||
544535 | X | X | Projectadministration: The speed of the message output has been improved. There is no longer any delay compared to executing the scripts directly in the command window. | |
544662 | X | sisNET: The error when performing a search multiple times for an object deleted in the job has been fixed. | ||
546257 | X | sisNET: The error that occurred the first time an object not activated in Explorer was called using the “Search for object” function has now been corrected. | ||
550099 | X | sisNET: Moving several labels using a fence now works again. | ||
550283 | X | sisNET: In the function settings dialog, the behavior of the setting "Use fence" has been corrected. | ||
551918 | X | sisNET: The dynamic functionality in PROTOTYP module has been corrected. | ||
552398 | X | sisNET: When opening the job manager, the option 'Show jobs from all commodities/ maps' is now activated by default. | ||
572942 | X | sisNET: When plotting, the frames from the sheet model were sometimes missing. This bug has been fixed. |
