The table below lists the fixes and enhancements in sisNET CONNECT Edition Update 2, with version number 10.06.00.04, released on November 26, 2020. Update 2 was built on PowerPlatform 10.14 and OpenCities Map 10.6.
| ID | New | Change | Bug | Description |
308802 | X | sisVIEW: an independent workflow was defined for sisVIEW (no longer derived from the sisNET ribbon). | ||
372087 | X | sisNET: Also, for object types that are created with a batch script, the entry in the explorer tree is activated. | ||
393603 | X | sisNET: The error when calling the SETLEVELSYMBOLOGY macro was fixed. | ||
420180 | X | sisNET: The final dimension of an orthogonal dimension was not correctly underlined. This is corrected. | ||
421285 | X | sisNET: Text replacement at the end of plot preparation starts again automatically. | ||
421938, 446526 | X | sisNET Ribbon: For editing/viewing the print template properties the corresponding icons were missing. The error is now fixed. | ||
445695 | X | sisNET: The tooltips of the object info box now show the descriptions of the functions instead of the keyboard inputs. | ||
450319 | X | sisNET: The error in IF ... THEN constructs using the GETOBJID function in commodity macros has been corrected. | ||
450748 | X | sisNET: The creation of a fence along a linear object (FENCEAREA - macro) works again. | ||
452528 | X | sisNET: Fixed a crash when saving jobs that contain only non-graphical changes | ||
453437, 455057 | X | sisNET: Fixed the crash when zooming in/out with the automatic explorer | ||
453902, 499616, 498969 | X | sisNET: Placing/moving/rotating labels now works correctly The GETPNTEXT, SETPNTEXT, SETPNT, PNT macro functions and the rotation of dimension texts have also been corrected. | ||
455399 | X | sisFLOW: Attributes not relevant to graphics can be changed in the form mask | ||
460675, 453902 | X | sisNET: The position of the newly placed or edited label was corrected. | ||
460703 | X | sisNET: The label to be placed (dynamic function) is now displayed with the correct color. | ||
460809 | X | sisNET: Fixed truncated message when using the TRQS module | ||
460847 | X | sisNET: New macro functions: - SIN, COS, TAN, ASIN, ACOS, ATAN, ATAN2 have been added to work with angle specifications in radians - VECTORDISTANCE serves as a replacement for mdlVec_Distance - GETSELECTEDVIEWINDEX as replacement for mdlWindow_getSelectedViewIndex | ||
466973 | X | sisNET: After starting sisNET the view was sometimes opened very small. This has been fixed. | ||
468821 | X | sisNET: The EXPANDCFGVAR macro function now also resolves variables containing multiple $(var) expressions. | ||
473873 | X | sisNET: The error during the initialization of the SROHR module has been fixed. | ||
476202 | X | sisNET: Stations can be created again with the PROTOTYP module. | ||
479545 | X | sisNET: the detaching of all raster files was corrected | ||
479578 | X | sisNET: Fixed the crash in the KSTR module when creating a line with connection to a busbar. | ||
482128 | X | sisNET: The error when displaying external documents from the form mask was fixed. | ||
482129 | X | sisNET: the command specific dialog settings (Dialog Tool Settings) have been fixed and are displayed again when a command is activated | ||
| 482130 | X | sisNET: editing as well as executing selection files (*.sel) works again | ||
482823 | X | sisNET: an sisNET object selected with Microstation element selection can be deleted with the DEL key. | ||
482824 | X | sisNET: When creating area-shaped objects with hatching, the angle option selected in the "Hatch Settings" dialog is now taken into account. | ||
482825 | X | sisNET: The bug that caused hatching to be missing in some cases when creating area-shaped objects with hatching has been fixed. | ||
495792 | X | sisNET: Referencing of DWG files works again. | ||
500323 | X | sisNET: The error that occurred after editing backstage rights was fixed. | ||
| X | sisIMS-Desktop: with the new 'RedirectWMSService' setting, an external WMS service can be redirected via sisIMS-IIS. This can be used for an HTTPS / HTTP redirection or for calling an external Password-Secured-WMS service. Example 1: HTTPS / HTTP redirection: -Use the following setting in the GRP file responsible for the sisIMS WMS: RedirectWMSService = http: //osmwms.itc-halle.de/maps/osmfree? SERVICE = WMS & -in the XWMS file the URL line with <URL> https: // <sisims virtual dir> /wms/request.aspx?service=redirectwms& </URL>. Example 2 redirection with user / password: -Use the following setting in the GRP file responsible for the sisIMS WMS: RedirectWMSService = http: //gdi1.geo.bremen.de/mapproxy/bv_kat/service? RedirectWMSBasicAuthentication = <user>: <password> -in the XWMS file the URL line with <URL> https: // <sisims virtual dir> /wms/request.aspx?service=redirectwms& </URL> replace. |
