Applies To | ||
Product(s): | OpenPlant Modeler | |
Version(s): | 08.11.09.XXX & Higher | |
Environment: | Windows 7/8/10 (64 bit) | |
Area: | Properties | |
Subarea: | ||
Original Author: | Harpreet Singh, Bentley Product Advantage Group |
In OpenPlant Modeler, Spec validation tool updates existing components in model automatically if spec has been updated for any field. But bolts and gaskets are left behind since these are not part of pipeline manager therefore user has to update them manually. In this article we will discuss the easier way to update bolts and gaskets in bulk.
Method 1
For more detailed steps Click Here
Now, item browser will have separate node for each component class as shown below:
Method 2
