ProStructures CONNECT for AutoCAD 2021 - 2024 Update 2 Readme
ProStructures CONNECT for AutoCAD Update 2
ProStructures CONNECT Edition for AutoCAD Update 2 (10.02.00.04) is now available on Software Downloads.
What's New Highlights
AutoCAD® Support
AutoCAD® 2021, AutoCAD® 2022, AutoCAD® 2023, AutoCAD® 2024 are supported by ProStructures CONNECT for AutoCAD Update 2.
Operating Systems Supported
Projectwise Integration
ProStructures CONNECT Edition for AutoCAD Update 2 supports:
Supported AutoCAD version
ProjectWise Version
ProStructures CE U2 and AutoCAD 2021
10.00.03.453* & 23.05.00.11
ProStructures CE U2 and AutoCAD 2022
ProStructures CE U2 and AutoCAD 2023
23.05.00.11
ProStructures CE U2 and AutoCAD 2024
23.05.00.11
*  Requires ProjectWise Integration Module for Autodesk AutoCAD 2022 CONNECT Edition
Structural Synchronizer Integration
Structural synchronizer CONNECT Edition x64 Version 10.03.01.06 is compatible with Update 2 on all versions of AutoCAD.
Structural Synchronizer Version Compatibility To Download
Structural Synchronizer CONNECT Edition x64 Version 11.01.02.09 No
Structural Synchronizer CONNECT Edition x64 Version 11.00.03.04 Yes
Structural Synchronizer CONNECT Edition x64 Version 11.00.00.15 Yes
Structural Synchronizer CONNECT Edition x64 Version 10.03.01.06 Yes
Structural Synchronizer CONNECT Edition x64 Version 10.01.01.04 No
AutoPlant Integration
ProStructures CONNECT for AutoCAD Update 2 is no longer compatible with AutoPlant.
Subscription Entitlement Service
Known Issues
